I can 100% tell you all that the 37x12.5R22LT nitto ridge Grapplers on the rebel 6 will not fit without rub.
Mounted one tire to the left front of a PDI unit today and confirmed While in air, Full turned to the right was tight, about a pen tip from rub and turning to the left rubbed horribly, with about 180* left to turn.
I'm changing it up to 35x12.5R22LT, Which should be fine and puts the OD circumference right at OEM 34.80.
