Build Order Question
rmcalhany
Nashville, TN
Does a truck go from E through G in one day (frame through trim)?
Then built the next day and assigned I after build? And J after QC? Are those done in the same day also?
Trying to get clarification regarding the codes. Sorry if this has been asked before - I can't find it - only a list of codes.
There is no simple answer to that question. Some trucks have gone through that transition same day, others have done it across 2 day depending on what shift the process started on, and at the opposite end there have been trucks stuck in the middle for weeks. So unfortunately there isn't a definite answer to your question. Maybe in a few months after that have worked through the initial start up pains of building a new truck things will be more consistent.
