Step 1 - Purchase your Rigid SR-M pro kit from https://brawlerfab.com/product/reverse-light-kit-with-rigid-sr-m-pro-lights-pt10030/
Step 2 - Connect both red wires to Auxiliary connect. Make sure to ground your negative wire to the truck. We ran out reverse lights to Aux 6.
Step 3 - Feed the wires from the front to back. Tip - Follow the wires already going back along the frame.
Make sure to utilize industrial strength zip ties to properly secure wires to the frame.
Step 4 - Mount the brackets by removing the tow hooks, and then reinstall with brackets attached.
Repeat process for the other side.
Step 5 - Attach your Rigid SR-M Pro backup lights using provided hardware.
Once you have everything properly secured. You’re good to go.
Step - (Optional). You can tap into the reverse lights. If you chose to tap into the your reverse lights, please use the provided hardware for ease of installation.
Step 6 - Testing your work! Go ahead, press the desired Auxiliary switch, or put your truck in reverse.
Congratulations! If you have any questions, please don’t hesitate to reach out.
