jrad801
Hi all, picking up my new white TRX tomorrow and had a question on wheels. Is anyone running the Black Rhino Chamber wheels in a 18x9.5 +12? I want to see if they clear the calipers before ordering if I can. If not I guess I will be a test case. I’ve seen other Black Rhino wheels in this size being run without clearance issues.
Assuming they do fit, will these be fine for higher speed desert use with stock tires or will that slight extra width and offset cause scrubbing (or worse) on the inside fender under suspension load? I plan to really use the truck in the desert but keep the stock tire size, no interest in 37s or spacer lift. I’ve got an AEV JL370 Rubicon EcoDiesel on 37s for technical trails and rock crawling.
Thanks!
Thanks!
