I'm trying to locate where are the actual connectors to connect accessories to the auxiliary power switches. If anyone has a pic of where on the truck they are located it will be highly appriciated.
@Skiborsy - very cool! I managed to find the wires. There are very much like @marksouth posted. There is an actual sticker on it that visibly says aux 1
The owners manual!@Skiborsy - very cool! I managed to find the wires. There are very much like @marksouth posted. There is an actual sticker on it that visibly says aux 1
Yeah, for reference, raptors have 2 each of 15, 10 and 5.Wow, aux 1 and 4 has some pop.
Yes, I had one. Only used three switches on that one for 3 pairs of front lights in them crazy bumper holes. It was kinda bright lolYeah, for reference, raptors have 2 each of 15, 10 and 5.
I would like to know if you could interrupt the ignition with one of these switches so as to use it as a kill switch when off, therefore thwarting someone who tries to scan your RFID fob from the street when you are in your house at night, they could unlock your car and try to start but unless they knew the ignition was hooked to a aux switch they couldn’t get it started, just a thought.
I ordered, it just sucks that we hav e to even worry about this.This is what I use. Absolutely works, I tested right next to the TRX w/ the fob inside, doors wouldnt unlock. Tried starting it with the key fob inside the box, wouldnt start. Or a Farady pouch which I got my son. Just search for “Faraday box” or “Faraday pouch”. Couple of months back a neighbor had his car stolen w. a relay, he saw what happened later off another neighbors security system. At first I tried a tin box & then an EZ pass bag but they didnt block the signal.
Sure. There's all kinds of games you could play. Use the output of one of the AUX circuits to drive another relay (so AUX #2 output wire to new relay terminal #86, ground terminal #85). Now cut your starter relay control wire, and connect one side to new relay terminal #30 (common), and the other side to terminal #87 (N/O). Your starter will now not operate UNLESS AUX#2 is on. To be even sneakier, program AUX#2 to be a momentary switch. Now you have to HOLD AUX2 on while pressing the start button.I would like to know if you could interrupt the ignition with one of these switches so as to use it as a kill switch when off, therefore thwarting someone who tries to scan your RFID fob from the street when you are in your house at night, they could unlock your car and try to start but unless they knew the ignition was hooked to a aux switch they couldn’t get it started, just a thought.
I almost understand all that, have to wait to get trx, the idea that you can program the aux to momentary or just a powered switch seems amazing to me, I would feel better having a diagram to look at for all that as all I want to do is break the path of power to starter or ignition. Does (N/O) mean non operational?Sure. There's all kinds of games you could play. Use the output of one of the AUX circuits to drive another relay (so AUX #2 output wire to new relay terminal #86, ground terminal #85). Now cut your starter relay control wire, and connect one side to new relay terminal #30 (common), and the other side to terminal #87 (N/O). Your starter will now not operate UNLESS AUX#2 is on. To be even sneakier, program AUX#2 to be a momentary switch. Now you have to HOLD AUX2 on while pressing the start button.
No Galils or Tavors?I have a couple ARs in case anyone tries to share my toys![]()
