Is there a way to disable the shift lock if the door is open? There’s a gate I have to stop at, open and then pass through get out and close, i can’t shift into D and roll through unless the door is closed..
It's not the alarm. If the truck doesn't detect that the seatbelt is engaged in the buckle, it does the auto-park thing. Try this as a test, instead of the extension, buckle your seatbelt behind you and see if you can avoid the auto-park "feature". If so, the extension is an option for you to consider.I’ve already disabled the seat belt alarm (saw how on instagram) it’s got nothing to do with seat belts. If you shift the truck into D with the door open, it won’t move, you gotta shift to park and back to D to get the truck to move
Say what? I drive without buckling up lot's of times, often for hundreds of miles at a time.It's not the alarm. If the truck doesn't detect that the seatbelt is engaged in the buckle, it does the auto-park thing. Try this as a test, instead of the extension, buckle your seatbelt behind you and see if you can avoid the auto-park "feature". If so, the extension is an option for you to consider.
In your first post you asked how to disable auto-park with the door open. What I described does it, especially if you have to raise off of the seat.Say what? I drive without buckling up lot's of times, often for hundreds of miles at a time.
In my 1st post?In your first post you asked how to disable auto-park with the door open. What I described does it, especially if you have to raise off of the seat.
