Anyone have a klunk,kick in the ass feeling when just about to stop/ start
TyRX
Texas
21 Silver TRX
69 Camaro w/ LS swap
I never understood this thread until over the weekend when I turned 1100 miles. The klunk magically appeared and a curse word slid out from under my breath. Then my 3 year old in the back says "what daddy?", oh nothing buddy, nothing....
Necrosan
Bay Area
21 RAM 1500 TRX
I recently have had this start occurring at right around 1825 miles.
tkdr6
Denver, CO
2013 Ram 3500 Laramie
I noticed that it started occurring on my TRX at about 3000 miles. Notice it when coming to a complete stop and when starting from a complete stop, still relatively subtle for me and you have to be paying attention but I’m extremely meticulous and noticed it right away.
Now have 5000 miles and went in for my first service and oil change. Had a master technician look at it and drive it, he thinks it’s relatively mild and considered normal and that it could be due to the locking rear end differential. They told me to watch it and if it gets worse to bring it back and they will look at it again.
For me it only happens when I’m in sport mode and driving the truck hard. Don’t seem to notice it when I’m in auto mode and driving conservatively.
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
Anyone figured this out yet? 4500 miles and doing it more noticeable now… TIA
tkdr6
Denver, CO
Anyone figure this out yet? It’s still relatively subtle for me but being overly meticulous it would be really cool to figure out what this is and if it’s considered normal or not
SPB_SLORAM
Patiently Waiting
Boston, MA
2019 Ram 1500 Laramie
On my old WJ, ‘13 ram and current ‘19 ram I’ve noticed I would get a similar feeling when driving aggressively (both accelerating and braking) for a while. If I drove conservatively for some time and rode the brakes more to a stop it would go away. Not sure if it’s a similar situation for you guys rather than something mechanically wrong.
JTR
Illinois
Waiting for my ordered '22 TRX
Following. Just ordered a '22 TRX and had a similar issue in my '19 Longhorn. I always passed it off to the fuel moving in the tank, but after reading through this thread it seems worse than what I experienced.
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
We did! Been driving it for about 500 miles since I picked it up from the shop, and itdoesn’t do it anymore... I’ll get all the details from the tech and post it here tomorrow!
Randychill
Arkansas
Name
Randy
2021 Ram TRX
Not yet waiting on the parts.
I’m still waiting on my parts. I checked on them yesterday and they are supposed to arrive on august 15th. The bump in the trunk is getting very annoying as the mileage gets higher.
tkdr6
Denver, CO
Really looking forward to hearing the details regarding what they did to fix this!
Thanks in advance for sharing!
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
Remove driveshaft from rear axle.. Remove band clamps from driveshaft slip yoke boot and separate shaft into 2 pieces, clean all old grease off the splined slip yoke and generously apply PFTE grease. Reassemble driveshaft and install new band clamps.
No more clunk/bump after we did this… very smooth!
I hope this helps! 👍🏻
SwarfWorks
Michigan
'21 TRX (x2), '19 Raptor, '13 Raptor
Mine just started this infamous clunk (more of a thud) at about 1800 miles.
Let’s hope pazosdaniel24 is correct. That would be a pretty easy fix.
tortolabob
Cape Cod
2021 Ram TRX
My TRX does not have this problem yet...I had a first generation Raptor that had this problem and grease on the splines helped but only for a short time. Ford eventually did a recall in which they replaced the drive shaft which solved the problem for good. 3500 miles on my TRX atm.
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
It Will work… it worked on mine, so far haven’t feel it once after 800 miles.
Hemibuck
Spokane
Charger Hellcat
Same. My mechanic said he thought it was the suspension. I'm gonn show him the greasing trick and see if that does it. Thanks for the info!
lootawi
TRX Noob
Dubai
Name
Sultan A Lootah
RAM TRX
I have the same problem and by time its getting worse and my TRX has only 2500 miles, im pretty sure its a drive shaft grease issue as i had this on my previous truck ! But what makes me suspicious is the clunk only occurs when i run the truck for a while and trans temp gets to its average temp. Not when its cold ! Idk if anyone noticed this as well.
Randychill
Arkansas
Name
Randy
2021 Ram TRX
I’m betting we’re not all on the same page with the bump thump stuff. Mine is definitely in the suspension or body mounts because I felt the same bump when filling up with gas the other day. My dealer ordered both rear shock and rear body mounts/ body shock absorbers but I won’t receive them till august 15 to find out if this works.
thetasigma1186
Clever, MO
LE RAM TRX
2010 Victory Vegas Jackpot
I agree 100% with this. Mine only does this after warmed to normal temp. Not when cold.
