Anyone have a klunk,kick in the ass feeling when just about to stop/ start
DanZman
Arizona
Name
Dan
Sierra Denali
Giving up is a great way to go. What are you going to move to?
Oh, maybe it was not clear. I’m ditching that truck and moving to a TRX. If the new truck does the same thing, I may move to a custom tune. At the very least the TRX will be much nicer than my current Denali, and it will have zero miles and a new warranty.
topdawg4ever
Ohio
Name
John
21' Ram TRX Hydro Blue
18' Durango SRT
I’ve got the same issue. Waiting for something to fall out from under the truck before I go through the 100 questions from Dodge’s service. It feels and sounds like junk.
TyRX
Texas
21 Silver TRX
69 Camaro w/ LS swap
I like that clarification much better (apologies for previous snarkiness)
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
Any news on this ? My dealer said it is perfectly normal with the 8 speed transmissions, but I still believe it is annoying and of course fixable…
Guns22
Long Island NY
2016 power wagon
Same here went to dealer told me same crap , it has got worse , only does it after truck reaches operating temp
RobR651
TRX Addict
Boise, ID
2015 Ram 1500
Have any of you guys with the clunk checked your fluid levels in the differential?
ceb
AR
My old trucks would do that with a slip yoke that needed greased. Thankfully mine is clunk free so far
Randychill
Arkansas
Name
Randy
2021 Ram TRX
Just left the dealership. They think it’s the rear body mounts. So their going to replace those and also the rear shocks and the shock that mounts to the rear end housing. I’ll report back hopefully with good news next week.
RobR651
TRX Addict
Boise, ID
2015 Ram 1500
That is not a cheap fix. Those shocks are expensive as hell
Randychill
Arkansas
Name
Randy
2021 Ram TRX
Thank god for warranty! I was already getting the drivers side rear shock replaced because the sticker was coming off. They wouldn’t just replace the sticker they replace the whole shock. Lol
FoShizzle
SoCal
Im at 7,000 miles and have started noticing the same clunk. My Tacoma did it for years and I never had any issues with it, but if there is a solution I'd really like to know. Pretty sure the truck didn't do this before.
Alienhead
Idaho
2015 1500 Longhorn
2021 TRX Granite level 1
There are a couple things that cause this that are normal. But don't assume this is what's happening. Ask the questions at the dealer. 1st is the learning process of the truck. It attempts to adjust to your driving as noted. This should resolve itself. If it does not then it can be reset to relearn your driving. 2nd is cold trans fluid. If the fluid has not warmed up enough you will get a hard couple up and down shifts in 1st and 2nd gear. There is a BGATF+4 flush/treatment that worked miracles on the 8 speed in my regular ram. I would consult the dealer about weather to use it in the TRX. "Should" be good.
Randychill
Arkansas
Name
Randy
2021 Ram TRX
Maybe we’re all experiencing something different. Mine feels like the spare tire is loose but it’s not. It feels like a rubberized bumping after taking off at every stoplight before I even make it to 5mph. I’m probably the the only one in this whole forum that averages 12-13 MPG. Lol. So there should be no reason the transmission should be doing this.
tungs10
SOCAL
I have about 4K+ miles and I now have this as well. SUCKS!!! I had a 2013 Sport that did the same and got rid of it because of it. In that truck it was only when I was in 4 wheel drive. I can't place what's going on but the feeling rear-ended its the best way to describe it as the truck seems to move forward an inch or so after. I dread going to the dealer and hearing the "I didn't notice anything".
SpamSpamSpam
Houston
I have the same issue and have noticed it getting progressively worse as my odometer creeps up past 9k miles. Granted it does feel awkward but I suppose that’s what the warranty is for. Btw, my wife drives a 2020 Audi SQ5 which is also AWD. Her suv has done the same thing since day one.
