Anyone have a klunk,kick in the ass feeling when just about to stop/ start
Zucco22
Atlantic Highlands, NJ
18’ m550i xdrive
Might be the typical 2-to-1 bump some 8 speeds have in the RAM's. I've noticed it in multiple Mopar vehicles, except for the V6'es.
The transmission is rock solid. Many of my friends have some version of it in their cars and even Rolls Royce uses them. Chrysler's programming is just ... not very good (hoping I'm not stepping on anyone's toes here). The transmission is also constantly picking up new patterns. If you'd do a lot of stop and go, it smoothes out again.
Dealer can also make it learn from scratch again (or you can disconnect the battery), which will solve it temporarily, but it'll pick up some weird pattern again sooner or later and do it again for a little while — if it's still the same issue.
Makes sense. It wasn’t happening when I first got the truck. Probably started around 3000 miles. I have 8500 now and still happening.
HellcatKevin
Pa
Name
Kevin
Trx, Hellcat challenger, Hellcat charger
Yep mine does it also, doesn’t bother me, I’m a master for Toyota, Tacoma’s and 4runners have done that same thing for ever
Serluna
El paso TX
2019 Ford Raptor
Mine does the same, I started feeling it when I had about 2000 miles and now almost 5000 i feel it is a little worst but i dont know if its just my mind. Dealer was not able to replicate like always and said to bring it back if it got worst.
HellcatKevin
Pa
Name
Kevin
What we tell Toyota custs is that it’s the drive shaft basically catching up with the transfercase which it is in layman terms, basically it’s like a torsion bar and it’s under pressure but when u stop and creep forward the tension settles and that’s what ur feeling, it doesn’t help that r trucks have like 13” or whatever of suspension travel also factors into it cause obviously the drive shaft is moving with the suspension
nutgambler
NJ
2021 Ram TRX
2013 Lambo superleggera edizione tecnica
ARMY
same issue with mine.. over 12500 miles so far. happened when new and still happens
NashRam
Texas
Ram 1500 Laramie
Had my truck like 4000 miles and lately it feels like as I’m slowing down just about to stop there’s a clunk in the rear and sometimes when I start accelerating the same thing I’m hoping it’s just something that has to do with the all wheel drive or maybe a bushing in the back almost feels like there’s a ring gear tooth missing sometimes lol , doesn’t do it when it’s cold but it does happen a lot
Mine just starting doing it with about 2200 miles on her.......
Randychill
Arkansas
Name
Randy
2021 Ram TRX
Mine started around 3500 miles and now have 5200 and it feels like it’s getting worse. I thought I figured it out last night when I was rotating my tires and every lug nut was less than 25 foot pounds of torque. So y’all might want to check the torque on your lug nut even though it won’t fix the bumping problem. I originally thought it was the spare tire being loose because it feels like rubber to rubber contact.
DanZman
Arizona
Name
Dan
Sierra Denali
I am really disappointed to be reading this thread. The 8 speed in my current truck('17 Denali 6.2) does this same thing and I absolutely hate it. Its honestly embarrassing to take people for rides in the truck and I have received comments like "whats wrong with your truck?". Sometimes I feel like the 3 speed auto in my '76 bronco works better than these modern transmissions.
raww1023
Tri-State
I have the same symptom didn’t notice until 2-3k mark as well. It also does not happen all the time.
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
I have the same exact issue in mine. Started around 3200 miles and it’s annoying and frustrating for sure to say the least. Taking it to the dealer tomorrow. Hopefully we can figure it out. Will post later if we do.
pazosdaniel24
USA
Name
Daniel Pazos
RAM TRX 2021
Did this solved the problem for you?
Steiger
USA
2019 Ram Longhorn
Mine doesn’t do this......yet. I remember reading about a truck that had this problem years ago. May have been the first Gen Raptor. They started taking the rear driveshaft off and cleaning the splines in the slip joint. Then greasing the splines really well and reinstalling. If my TRX starts doing this, that is what I am going to try unless someone finds a better cure
Randychill
Arkansas
Name
Randy
2021 Ram TRX
I’m going to the service department Saturday to get this figured out and I’ll bring this up to the technician. I kinda figured it was probably the the strut that goes from the rear end housing to the frame or a bushing somewhere. It’s very annoying! It feels like something hitting the tailgate every time I leave a stoplight. Thanks for the heads up on this.
Steiger
USA
2019 Ram Longhorn
You’re welcome. Please let us know what you find out
DanZman
Arizona
Name
Dan
Sierra Denali
Good luck to all. I know that over on the GM forums people have been able to cure these issues with a custom tune on the trans. I know that my solution is to sell the truck and move on. At this point I’m pretty sure that my driving style will bring it back in the TRX and that I’m just going to have to let all the power keep me from dwelling on it.
TyRX
Texas
21 Silver TRX
69 Camaro w/ LS swap
Giving up is a great way to go. What are you going to move to?
TReX-RAM
TRX Junkie 💉
CA
TReX
I have noticed mine getting to be a little worse as well. I thought I got rear ended on Sunday. Another car backed out of a parking spot and got really close to me and I purposely inched forward so I didn’t get nailed in the rear (insert inappropriate joke here). As I slightly moved forward the drivetrain and/or suspension seemed to bind up a little. I thought I got nudged. I got out of my truck to confront the lady and she bailed. I was pissed and went to chase after her when I noticed there was not even a scratch on my bumper. Damn, that would have been funny! Lol
I haven’t a clue what the fix is tho.
Terry w
TRX Noob
Michigan
Rubicon
Mines doing the same ... ZF did a audit on them ... they used the wrong size o-rings .. and plates not torqued to spec... waiting on recall... I have had my in the first 500 miles with this problem dealer said there was no problem...
