Aftermarket Industries Fuel Pump
JKMTRX
South East Florida
23 TRX
Unless you're making some crazy power with a turbo or Whipple, I doubt you need it. The fastest stock blower truck is in the 9s making well over 1,000 whp and uses a BAP on the stock pump.
Got any details about the build? Video? Thanks
My stock one is failing and going to buy a new one. Just curious about this pump, although it is 3x the cost if i don't have to worry about replacing it every damn year could be worth it. I have about 7.5k miles on my truck since tuned (14k total, its a 2023). I know stock with BAP can handle the needs beyond even what i might do. I bought ID1300 Injectors with the intention of going full E85 and higher boost.
If i were to go crazy i think i would go with triple pump option, but def don't need and the trx is now my daily.
BAP = shortened pump lifespan. Great for budget track cars. Bad for daily driven builds or high heat climates.
Not to mention going with a return style system is going to require you to maintain almost half a tank of gas for pump cooling purposes. Less than 200 miles range on e85 is a PITA.
Yeah, even through I rarely go below 1/2 a tank even with stock I don’t want that limitation.
This morning the sensor messed up again and got the code. Think I’ll just do OEM for now then see what I end up doing by adding more power. Truck is running fine, just sensor issue today. Either way it’s being replaced hopefully latest next week.
Yea, it was the Moe's Performance shop truck. Matt (the owner) ran a 9.99 and then ended up selling the truck a little while back. To my knowledge, it's the fastest 2.4L IHI TRX without compound boost or nitrous.
Ported blower and bearing plate
2.50" upper
ATI 10% lower
Gearhead adjustable idler
ARH headers w/ cats
5" cold air intake
Nick Williams 108mm TB
ID1300s
JMS dual BAP
Tuned by ZH Tunes on E85
Moe's Performance TRX
I disagree. I've run BAPs on multiple vehicles for tens of thousands of miles, most of them in the Houston heat. Sure, the pump might wear out faster, but I've seen fuel pumps last hundreds of thousands of miles without issue.
Depends on how you have your pump set up. If you're running full tilt all the time, sure, but modern well thought out return systems only overflow by a small margin, limiting how much extra work the pump has to do.
I spoke to Fore. They recommend keeping 1/3-1/2 a tank. I have plenty of Fore setups before on vehicles but the required fluid level to act as a heat sink for longevity varies depending on the specific vehicle design and application. I could run my V down to 1/8 tank on a Fore triple pump without issue. For the TRX every shop I know recommends to keep it higher.
It has to do with the specific heat sink capacity in the OEM pump. Some pumps can handle the higher current draw better than others. Coil winding location in regard to the case has a lot to do with this. From what I have seen, MOPAR quality is the lowest of any brand I have done builds in. But at its core, a BAP is a bandaid. And since the TRX won’t throw a code for low fuel pressure you better have a gauge to monitor along with an alert (currently doing that on the stock pumps) since you won’t know when a pump goes out (with or without BAP). So you have a build with over 200k miles on it with a BAP the entire time? That is impressive.
FWIW, we have had 4 stock pump failures now on this forum and all from folks running e85. I’m thinking the stock pumps are either already getting pretty warm or the OE quality is just crap.
But I stand by my statement…and I really don’t know what your point is. I said BAPs shorten the lifespans and you responded with “disagree” but then said BAPs do wear out the pump faster. So…
Their quality control is awful, even worse than my Raptor. However, i do love the TRX way over the Raptor. I just opted to re do the stock pump for now. Figured if it happens again in less than a year and 7.5k miles i will definitely know what direction i want to go with the truck. I have been all over the place. Between keeping where it is (has been reliable and don't think my setup is putting too much stress on the engine) to doing a 426 stroker with 3.8 whipple.
Most of those fuel systems require a partially full tank not for cooling, but because they lack the factory fuel pump bucket. They'll run dry under any high G loading with a near-empty tank, which obviously ends poorly. It also could just be Fore covering their ass, you never really know unless you ask and they decide to give you an honest answer.
Yes, adding more voltage and amperage creates more heat... when you're using the BAP, which is only above 50% throttle if you have it setup like mine. Below that, i.e. for nearly ALL my driving, there's no added voltage to the pump, and thus no extra wear. It only kicks in when you romp on it, which isn't that often or for that long, so the pump never really gets a chance to heat up that much. When you do hit on it, it might heat up a little bit, but it quickly cools down.
Sure, on a race car that's always full throttle, it would maybe be an issue, though I've seen plenty of those that make the BAPs work for extended periods as well. I disagree they're a bandaid. That's like saying adding a smaller upper pulley is a bandaid instead of buying a Whipple. Sure, you're pushing OEM parts past their normal working range, but that doesn't mean they're going to fail. Ask me how I know, I've engineered parts with hilarious safety factors before just because it's convenient or there's some other design goal. It's hard to know the limitations of a given part without a ton of R&D or lots of real-world data.
I have a 2014 Ram with 210k miles on the factory fuel pump, and it runs 11s NA, zero issues. Making well over 500 at the crank. No BAP because it isn't required, but my statement was to point out that you can make a factory fuel pump run for a reaaaaaally long time. Tons and tons of guys running OEM MOPAR pumps on the 5.7" Hemis without issue, many with E85, boost, or otherwise.
Four issues on an entire forum is a FAR cry from being a trend. People don't come to a forum to complain when their stuff works just fine, they just keep on with their lives.
You said "Great for budget track cars. Bad for daily driven builds or high heat climates." I disagree with those statements, not that it might technically lower the life of the pump by some indeterminate amount that won't actually affect anyone because it could be at half a million miles instead of 600k.
In closing, I understand your points and it sounds like maybe you've had some bad experiences with BAPs. While unfortunate, it doesn't necessarily mean they're all bad.
The way the Aftermarket Industries pumps are made and then venturi system they use, you can run the tank all the way down like you normally would.
They have drag tested their systems (inertia when taking off) with only 4gal of gas and the system doesn't drop pressure.
Whilst the price of the kit is high, the quality is incredible, everything is all MIL spec wiring (military and aerospace) which in itself costs a lot.
I've also seen first hand on a customers car who back in the day used one of these AI pumps on his car without the MIL spec wiring and the pressure dropped, after consulting with AI he got the correct MIL spec wiring and it solved the issue. I personally would have not thought that was possible but it was.
These pumps as said are the best you can use, if you take a little time and watch a few of the videos that they put out about pumps you will soon realize it goes a lot deeper than you think compared to just throwing any old fuel pump into it.
Thanks for weighing in. I haven’t talked to anyone yet running these pumps but sounds like they are worth the $.
Great to hear!
Thanks for the explanation on how a fuel pump and BAP work. I have built close to a dozen high performance vehicles over the last 20 years, utilized all of the options, worked at a shop, and also happen to be an engineer (but not one of those boring ones like civil). None of what you said changes my statement and you agree that is decreases life expectancy. The longest I have seen a BAP driven OE pump survive in AZ heat is about 3 years. Your analogy to suggest pump life expectancy is minimally affected is to compare to an OEM pump without a BAP? Makes no sense. Of course if you don’t push it outside the intended operating conditions then you can have a decent life expectancy if the design is robust.
Out of the roughly 15 or so folks on this forum that run e85 consistently as their DD, 4 have failed. No pump failures on pump gas builds that I am aware of. That is a surprising statistic. If you think that is purely coincidence and nothing to note then there’s no helping you understand. If you think I’m not in touch with a lot of forum members who have builds then you haven’t been on this forum very long.
Again though, we agree that adding a BAP decreases the life expectancy of the OEM pumps. What we disagree on is how much for this specific application. Since you’re an engineer then you should understand the Arrhenius model which is applicable here for the pump design with specific attention to seals and insulators. Everything electrical is going to have it’s life expectancy directly impacted by the temperatures it sees. That is not up for debate.
Tacking onto the conversation about pump reliability though is also the reliability of the BAP. You have added another failure point where something as simple as a popped fuse can now lead to running your motor lean without any warning unless you again add in a monitoring gauge and alert.
Running the fuel system at the intended voltage/current and pressure is always going to be the desired option for longevity and reliability.
Aight dude, I got better things to do than get into a dick-measuring contest on the internet. I wish you the best but I'm done talking to you about this.
justboltons.com BwoodyPerformance.com Granger Chrysler Jeep Dodge RAM OffRoadAlliance.com/ solisracinggroup.com Mark Dodge.com Forced Induction Interchillers SDHQ Motorsports
