AFE has a transmission pan for pre-order.
Only problem is that in the description, it says for the 850RE and 8HP70 transmissions. But at the top it says for 21- 24 TRX 8HP90/95 transmissions. It does look to be the same shape and bolt pattern as the TRX
afepower.com
aFe POWER Pro Series Transmission Pan Black w/ Machined Fins
Increased oil capacity:This transmission pan has an increased fluid capacity of approximately 2 quarts over stock for better performance over a longer duration. Built-in internal/external fins:Built-in internal and external fins transfer heat from the fluid to the outside air for maximum...
