HOT! Access LOMAX Stance Tonneau Covers with RIGIDLINK Locking System for the TRX!
Johnny@JustBoltOns
TRX Maniac
Central Florida
2005 Mustang V8 Swapped / Insane Long Mod List.
RIGIDLINK™ LOCKING SYSTEM
Solidly secure cover at approximately 90° angle for full bed usage and prevent contact with truck's rear window.Vertical position blocks 3rd brake light.
AUTOMATIC DUAL LOCKING SYSTEM
Release both locks simultaneously by pulling cord from either side to fold each panel. Heavy duty nylon latches provide 1/2 in. surface for solid positive engagement.
WEATHERTIGHT SEAL
Water-shedding design and waterproof hinges combined with continuous seal along the entire length of side rails route water away from the box without gutters or drains.
AUTOMATIC TEN POINT LOCKING
Unfolding each panel locks the cover automatically with heavy duty reinforced nylon components, no need for a key or complicated locking mechanisms.
MOLDED STORAGE BRACKETS
Retractable bungees hold tonneau cover secure while standoffs with rubber pads keep panels properly spaced in the folded position. No adjustments needed.
TIGHT BITE™ CLAMP
Installs in minutes without the need to drill into your truck box. Specifically cut 'teeth' maintain superior grip and exceptional strength.
STRONG YET LIGHTWEIGHT
Extruded aluminum channels support panels to hold up to 400 lbs. of evenly distributed weight, while weighing approximately 50-60 lbs. for a high strength-to-weight ratio.
We currently have 2 styles in-stock of these:
I put one of these on my truck mid-October. Love it, no regrets. They are built by Agri-Cover, which assembles them in their facility in North Dakota, and I've always had great luck with their products. Definitely recommend.
How are the brackets on the roof secured? They seem a little odd compared to how some of the other covers are secured when folded up against the rear window.
it requires drilling into your cab roof with some self-tapping screws.
Just kidding. :) They use strong double sided tape.
Glad to hear that! We've only sold a few of this style so far but so far no complaints, and that tape holds pretty strong from what we have seen!
It's definitely different but I've had my share of BAK folding tonneau covers and was never a fan of leaning them right against the back window so it's about time a manufacturer like Access comes with this before BAK did. Unless you are cautious and use some towels, most tonneau covers leaning right up against the back window will leave a mark.
Is the finish of the panels as poor as the pictures make it out to be? If you follow the in stock link to the website, the panels look terrible.
Definitely not, that's just the resolution of the images that the manufacturer provides us on the different finishes.
WEATHERTIGHT SEAL
TIGHT BITE™ CLAMP
We have 2 more of the Black Diamond finish instock today: https://justboltons.com/access-loma...ram-box-short-bed-2021-2024-ram-trx-g4040039/
WEATHERTIGHT SEAL
TIGHT BITE™ CLAMP
We just got a few more in and we also have 3 of these: https://justboltons.com/access-loma...ram-box-short-bed-2021-2023-ram-trx-b4040039/
Bumping these as we still have a few! You are welcome to use the forum discount code!
