Yup, 3 for 3 on this forum with dumb hub dyno numbers. Most shops don’t know how to setup the correction factors properly.The hub dyno is most likely the factor for skewed numbers.
Again, I’m not sure how to make it any more Mickey Mouse for you:You are not the worlds first idiot. Google hellcat FI interchiller dyno results so you can see reality.
It’s not misinformation until you’ve proven it wrong. You can assume anything about any car, but it takes concrete evidence to substantiate a claim. I have presented my evidence, now I’m waiting for yours. Cheers,Yup, 3 for 3 on this forum with dumb hub dyno numbers. Most shops don’t know how to setup the correction factors properly.
Unfortunately threads like this just become misinformation for new folks on the forum.
Easiest solution is for someone to verify my results independently.Glad to see your truck running so good! Let's settle This. You got a Draggy? Or even better access to a strip? Let see some 0-60 or 1/4 mile times.
No one needs to build another identical truck. You already have the unicorn. Just go get a time slip and prove it. We are excited that you are happy with your build but the numbers you are claiming simply do not mesh with reality. Please prove us wrong.Again, I’m not sure how to make it any more Mickey Mouse for you:
Show me a TRX with the same mods, dyno, and we can take it from there. Until then, it’s all white noise.
That’s more work. I’ve done my part, the burden of proof is on y’all. Let me know what the results are.No one needs to build another identical truck. You already have the unicorn. Just go get a time slip and prove it. We are excited that you are happy with your build but the numbers you are claiming simply do not mesh with reality. Please prove us wrong.
I’ll add more info:First of all... that is a good looking truck.
I'm afraid the gang is right, your dyno numbers definitely show close to 740 to the ground but in reality it isn't making that much. It is easy to manipulate those results and should be used for point of reference in my opinion. Case in point I made 758whp with a fully built, whipplecharged, cammed, heads, exhaust, ice boxed motor on 91. Do you really think you make a few less hp than me with a chiller and slip on pulley? With another 180 to ground you should be in the what high 10s low 11s? You didn't drop a full second in the quarter from some colder air and 1-1.5 more psi.
I wish the folks on here would a have a little more patience though and realize many on this forum haven't done this sort of stuff. I'm sure from his perspective he's thinking "what do you mean it didn't make that much it's right there on the sceen?!" Share your knowledge from a very layman's perspective otherwise the forums can be very off-putting for those trying to learn. Just my 2 pennies.
6th is 1 to 1 but is too fast for dyno is my understanding. 5th is what the tuner and shop recommended I run in.Hold on a minute, isnt 6th gear the true 1:1 on these rigs? A lower gear pull would skew #s quite a bit I would think.
Just show me a truck with the same mods dyno. That’s all it takes. It’s Mickey Mouse at this point.You seem pretty certain. I recommend meeting up with AZDinopwr, lining them up and setting him straight.
I would be happy to detune my truck to 720 awhp, prove with a dyno sheet that that is where it is at, and then run them side to side with $10k on the line just to make it worth the time.Just show me a truck with the same mods dyno. That’s all it takes. It’s Mickey Mouse at this point.
I get your point but patience is also reserved for those that deserve it. When the comments out the gate were condescending about “the op is clearly the only man on earth to think outside the box” to make this power level…. plus …. the inability to actually take the time to understand the math on why his dyno sheet is physically impossible from a conservation of energy standpoint then I’m not going to waste my breathe trying to be gentle and supportive. Others tried that route in this thread and his response was that they need to prove him wrong.First of all... that is a good looking truck.
