325/60R20
ColoradoTRX23
Colorado
2023 TRX
Picking up new granite TRX this week and have a set of 20x10 -18 Fuel Mavericks ready to go. Installing 1.6 & 1.5 Eibach springs.. I’ve seen some 35” setups posted on here but not many 325’s. I’m concerned about rubbing on the 325/60R20. If you have any experience with this setup your opinion would be appreciated. Thanks!
It’s a half inch difference… not sure what your asking… basically a quarter inch of additional rubber out and up from the rim… well since you are going from 18-20, 1.25” less to the radius vs OEM, and .25” less width… they are virtually identical.
I edited my post to clarify my ask…. Thought it was obvious but I guess it wasn’t.
You should be fine with -18 offset and stock tires. 37s, the rub is slight. Definitely make sure you get an alignment done.
Same as above. I run 325/60R20 tires with 20x10 wheels with -18 offset on stock suspension and it will slight rub sometimes near full lock.
I have 20x9 +0 with 325/60r20 (Radar Renegade RT) with no rubbing.
I run 325/60/20 Wildpeaks. 20x9.5 +15 Vossen's. No issues. and ill just say also that the ride is exponentially better. Those goodyears are SHIT.
