Since the trx uses the same front diff as the rebel etc… there is a front 3.92 differential already available.
Does anyone know if our rear axle uses the generic advantek D60 carrier? And if there is a 3.92 pinion and gear assembly available? Maybe from nitro or grizzley or whomever?
Since our trucks are limited to 118 anyways, we have a lot of gearing and rpm unused.
(And for the mpg folk, going to a lower rear end gear with a transmission with 2+ overdrive gears actually helps mileage)
Not to mention more acceleration grunt and crawling grunt.
Anybody know anything about the rear gear set?
