2023 - Left Turn Signal Will Not Reset
Mine still work the original way after the replacement. When moving forward permanently, they turn on auto brights. Not permanent brights.
Stalk forward enables auto brights (if your switch is in auto mode). But it enables permanent brights if the switch is set to "on".
Ok thank you, sounds like its working correctly when in "on" but when in "auto" mode I'm not getting the message on the dash saying auto high beams engaged on the cluster when the stalk is moved forward. I believe before the replacement I would see that message.
In auto mode, it will only show high beams on when they're actually on. During normal driving (lights on, but not brights), it won't show the blue light symbol. As far as the initial notification that you've enable high beams, that message shouldn't be persistent. Is that what you're talking about?
Correct that initial notification that pops up in the cluster letting me know they are engaged (right after I move the stalk forward) I have not seen since the replacement part was installed. I just picked up the truck today, so I haven't driven it at night to see if they work.
Just tested mine, which was replaced over the summer. I still do get the notification that momentarily flashes 'enabled' or 'disabled'
