2.8 pulley and tune
Kingsingh15
Michigan
Hey guys right now I have a 3.1 pulley and tune and thinking about going to 2.8 pulley and injectors. For those of you running a 2.8 on 93 pump how’s daily drive ability and differnt? Also I should notice a big difference going from 3.1 to a 2.8 pulley I’d imagine?
AZDinoPwr
TRX Addict
Arizona
2021 Ram TRX
View attachment 87236Hey guys right now I have a 3.1 pulley and tune and thinking about going to 2.8 pulley and injectors. For those of you running a 2.8 on 93 pump how’s daily drive ability and differnt? Also I should notice a big difference going from 3.1 to a 2.8 pulley I’d imagine?
I wouldn’t say big difference on pump gas. Big difference on e85 though. No changes in driveability as long as you have a good tuner.
TRXNUT
ON
Is it mandatory to have a tune with 3.1 pulley? I've read other places it's not necessary.
K
Kingsingh15
Michigan
I think some people run a 3.17 with a tune but I did the tune just to be safe with the 3.1, plus the tuning makes it feel completely different!
Mack0092
Pembroke, MA
2020 Mercedes GLE, 2015 HellCat Challenger, 2011 F350 King Ranch
I have the Dusterhoff DT 877 package, 2.82, injectors, tune, T-stat, S&B, tuned for 93. Prior to that I ran a Incognito and the S&B. The two don’t even compare, the truck drives like stock when I’m putting around town and is a monster when you get on it. Only thing I notice more now is the fan kicking on more often due to the T stat.
K
Kingsingh15
Michigan
I have the Dusterhoff DT 877 package, 2.82, injectors, tune, T-stat, S&B, tuned for 93. Prior to that I ran an Incognito and the S&B. The two don’t even compare, the truck drives like stock when I’m putting around town and is a monster when you get on it. Only thing I notice more now is the fan kicking on more often due to the T stat.
That’s awesome, pretty much everything I’ll get in my package as well! I have the 180 t stat on it already. What was your whp?
AZDinoPwr
TRX Addict
Arizona
2021 Ram TRX
I agree once you tune there is a decent difference. Not like having a 3000 lb car with that kind of difference but it’s there. The OP however already has a tune. Going from 3.17 to 2.85 is roughly 1.5-2.0 PSI jump or 30-45 whp. I highly doubt that’s going to have that same “monster” differential that you felt.
Mack0092
Pembroke, MA
Unsure, it was remote tuned due to my shop not having a AWD Dyno. My Hellcat challenger with almost identical mods + catless mids made 771WHP.
Mack0092
Pembroke, MA
Agreed, just posting my experience going from the roughly 12-13lbs with the incognito to 17lbs with the 2.82.
TRXNUT
ON
I was thinking about doing a upper pulley to add a bit but I didn't want to get into a tune injectors, T-stat and all that jazz as of yet until my warranty is up. I've read that guys are running the 3.1 upper without a tune.
