1 more
Looks tough! Where did you get the spacers from? I want to try and support the vendors on here.
Direct from Bora. Don’t think any of the vendors here work with them.Looks tough! Where did you get the spacers from? I want to try and support the vendors on here.
Do you have any lift springs installed with your 37’s?1.5” spacers installed. Some trimming required with 37s.
Perfect stance IMO
View attachment 118655View attachment 118656View attachment 118657View attachment 118658
Yes eibach 1.6 fronts and 1.5 rearsDo you have any lift springs installed with your 37’s?
You think the 2.7 fronts would clear with no trimming?Yes eibach 1.6 fronts and 1.5 rears
Not sure it would make a diff. Its not up or down thats the problem. Its behind and slightly to the right (of drivers tire) and behind and to left of pass tireYou think the 2.7 fronts would clear with no trimming?
Thanks man! But honestly, I didn’t even check to see how much clearance there was since the factory studs sat flush with the end of the spacer. If there are pockets on the backside of the wheels, then I would imagine you would be fine with 1.25s. Amazing that I’ve had my wheels off like 10 times and never noticed them having pockets. I think there is a forum post from someone saying 1.25s will work without trimming the studs. I would definitely go for that versus having to shave the factory studs.Looks awesome ! I am wanting to order Bora spacers today. I would like to do 1" or 1.25". I do not mind shaving the factory studs down, espacially the smooth tips of the studs. What was your experience with the 1.5" spacers? With the pockets on the back side of the factory wheels, what amount of shaving of the factory studs am I looking at with factory wheels and 1" or 1.25" spacers ? Thanks for the feedback.
Great looking truck you have. Love all the front end lights and bumper.
Looks great! Thank you for taking the time to make these posts.Better photos today. Mild off-road and no rubbing.
If you drew a straight line down to the ground at the widest point of the black plastic fenders, the tire is just a very small amount outside that line up front and even with the line out back.
1.25” Bora spacers
No factory stud cutting needed.
Rides identical. You wouldnt even know they're on there. And no alignment is needed assuming your alignment was good before install...How does it ride compared to stock with the spacers on? Also did you get an alignment after?
It is no different.How does it ride compared to stock with the spacers on? Also did you get an alignment after?
Looking forward to the pics!It is no different.
Getting these factory bead locks mounted up and then swapping them out Saturday Am. I’ll check torque on the spacers while swapping out the wheels.
